-20%
Drone Dji DJI Mini 4K (EU)
239 € 299 €
description[ARMEMENT] OERLIKON 20mm : Documentation Empty[ARMEMENT] OERLIKON 20mm : Documentation
Oerlikon 20mm - Documentation:
https://youtu.be/6yCxITYzW-0
https://youtu.be/k6hEcuYXpGg
Documentation HNSA:
http://archive.hnsa.org/doc/gun20mm/index.htm
https://www.rockislandauction.com/detail/70/2502/general-motors-mk4-oerlikon-20-mm-cannon
[ARMEMENT] OERLIKON 20mm : Documentation 20mmgun1
[ARMEMENT] OERLIKON 20mm : Documentation 20mmgun2
[ARMEMENT] OERLIKON 20mm : Documentation 20mmgun3
[ARMEMENT] OERLIKON 20mm : Documentation 20mm-Oerlikon-AA-Gun-Mark-4-No-Grid
[ARMEMENT] OERLIKON 20mm : Documentation 20mm-Oerlikon-AA-Gun-Shoulder-Rest-Ref-1
[ARMEMENT] OERLIKON 20mm : Documentation 20mm-Oerlikon-AA-Gun-Shoulder-Rest-Ref-2
[ARMEMENT] OERLIKON 20mm : Documentation A6f91d31-098a-4a3d-8966-d7900cf82ac6
[ARMEMENT] OERLIKON 20mm : Documentation Fig001
[ARMEMENT] OERLIKON 20mm : Documentation Fig068
[ARMEMENT] OERLIKON 20mm : Documentation Fig073
[ARMEMENT] OERLIKON 20mm : Documentation Fig078
[ARMEMENT] OERLIKON 20mm : Documentation Fig080
[ARMEMENT] OERLIKON 20mm : Documentation Fig082
[ARMEMENT] OERLIKON 20mm : Documentation IMG-14391
[ARMEMENT] OERLIKON 20mm : Documentation IMG-14475
[ARMEMENT] OERLIKON 20mm : Documentation IMG-14526
[ARMEMENT] OERLIKON 20mm : Documentation IMG-14534
[ARMEMENT] OERLIKON 20mm : Documentation Oerlikon-20-mm-cannon
[ARMEMENT] OERLIKON 20mm : Documentation Pg002
[ARMEMENT] OERLIKON 20mm : Documentation WNUS-2cm-70-mk234-British-sketch
[ARMEMENT] OERLIKON 20mm : Documentation WNUS-2cm-70-mk234-RAF-pic
[ARMEMENT] OERLIKON 20mm : Documentation WNUS-2cm-70-mk234-sketch
[ARMEMENT] OERLIKON 20mm : Documentation CV-12-20mm-1945
https://www.youtube.com/watch?v=z8gLeIlvDJg
https://www.youtube.com/watch?v=v5_o6Hu0J90
Projets en cours:
[ARMEMENT] OERLIKON 20mm : Documentation Animiertes-gif-von-online-umwandeln-de-2
Caboteur Blythe Star 3D
Cuirassé Bretagne 3D
SS Delphine 3D
description[ARMEMENT] OERLIKON 20mm : Documentation EmptyRe: [ARMEMENT] OERLIKON 20mm : Documentation
Sacré morceau d'histoire. Avec le Bofors c'est sûrement le canon AA le plus connu.
Merci pour les plans détaillés!
[ARMEMENT] OERLIKON 20mm : Documentation D0UpPb-20mm-mk10a
[ARMEMENT] OERLIKON 20mm : Documentation D0UpPb-20mm-mk10b
[ARMEMENT] OERLIKON 20mm : Documentation D0UpPb-20mm-mk24a
[ARMEMENT] OERLIKON 20mm : Documentation D0UpPb-20mm-mk24b
[ARMEMENT] OERLIKON 20mm : Documentation E0UpPb-20mm-mk2a
[ARMEMENT] OERLIKON 20mm : Documentation E0UpPb-20mm-mk2b
[ARMEMENT] OERLIKON 20mm : Documentation E0UpPb-20mm-mk4a
[ARMEMENT] OERLIKON 20mm : Documentation C0UpPb-20mm-mk4b
[ARMEMENT] OERLIKON 20mm : Documentation C0UpPb-20mm-mk5a
[ARMEMENT] OERLIKON 20mm : Documentation C0UpPb-20mm-mk5b
Hi Bob!
Si Vis Pacem Parafilmum
Telle est la Voie !
Merci!
Projets en cours:
SS Delphine 3D
Salut Pascal,
Belle documentation j'ai quasiment les mêmes plans sauf ..... les trois feuilles de plans d'un classeur apparemment, par exemple le plan Barrel N°299650 je serai curieux de savoir ou tu as trouvé ça ??? !!! Interrogation Interrogation
Alain
J'avais trouvé ça ici, mais 1000 $ le livre: sourire
https://forums.g503.com/viewtopic.php?t=319195
[ARMEMENT] OERLIKON 20mm : Documentation IMG_14545
Projets en cours:
SS Delphine 3D
Le livre a déjà été vendu, dommage ...... Rolling Eyes Rolling Eyes Shocked Shocked
En même temps il faut les lacher les 1000 ! Laughing
Un site interessant avec ce modèle très fidèle du MK4 du P109 au 1/6.
https://modelingmadness-com.translate.goog/review/misc/v20mm.htm?_x_tr_sl=auto&_x_tr_tl=fr&_x_tr_hl=fr&_x_tr_pto=wapp
[ARMEMENT] OERLIKON 20mm : Documentation 20230112160615
[ARMEMENT] OERLIKON 20mm : Documentation V20mmc
[ARMEMENT] OERLIKON 20mm : Documentation V20mmd
[ARMEMENT] OERLIKON 20mm : Documentation V20mme
[ARMEMENT] OERLIKON 20mm : Documentation V20mmf
[ARMEMENT] OERLIKON 20mm : Documentation V20mmg
[ARMEMENT] OERLIKON 20mm : Documentation V20mmh
[ARMEMENT] OERLIKON 20mm : Documentation V20mmi
[ARMEMENT] OERLIKON 20mm : Documentation V20mmj
[ARMEMENT] OERLIKON 20mm : Documentation V20mmk
Projets en cours:
SS Delphine 3D
Je connaissais aussi ce lien et ce modèle, effectivement il est très beau !
Merci pour toutes ces infos
Le premier type de support "tombe" bien, je vais devoir le  scratcher
C'est parce que la vitesse de la lumière est supérieure à celle du son que certains ont l'air brillant avant d'avoir l'air con.
Legalize intelligence
Avant de parler, assure toi que ce que tu vas dire est plus important que le silence.
  Belle documentation. J'avais trouvé a peu prés les meme ,en Angleterre,cher  John LAMBERT qui publiait d'excellents plans de navires de guerres anglais et aussi des plans d'armement .j'ai acheté a l'époque,années 1988 environ des plans de Oerlikons  Entre temps, je découvre un magasin espagnol qui vendait des canons de 20 mm au 1 /32 en métal blanc, de trés bonne facture  J'ai du faire des affuts suivant le plan anglais Ceux de la boite ne correspondaient pas
[ARMEMENT] OERLIKON 20mm : Documentation 7zgs
 Les canons espagnols de marque Talhoer au 1/32 ,en métal blanc
[ARMEMENT] OERLIKON 20mm : Documentation H044
  L'affut double Mark 24 au 1/32, impression 3D, de Shapeway
un dossier bien complet
https://archive.hnsa.org/doc/gun20mount/index.htm
[ARMEMENT] OERLIKON 20mm : Documentation Capture-d-e-cran-2023-04-17-a-11-24-37
[ARMEMENT] OERLIKON 20mm : Documentation Drum1
[ARMEMENT] OERLIKON 20mm : Documentation Plate1
[ARMEMENT] OERLIKON 20mm : Documentation Fig002
[ARMEMENT] OERLIKON 20mm : Documentation Fig003
[ARMEMENT] OERLIKON 20mm : Documentation Fig004
Projets en cours:
SS Delphine 3D
https://archive.hnsa.org/doc/gun20twin/index.htm#pg13
[ARMEMENT] OERLIKON 20mm : Documentation Fig13
[ARMEMENT] OERLIKON 20mm : Documentation Fig14
[ARMEMENT] OERLIKON 20mm : Documentation Fig31
[ARMEMENT] OERLIKON 20mm : Documentation Fig32
[ARMEMENT] OERLIKON 20mm : Documentation Fig42
[ARMEMENT] OERLIKON 20mm : Documentation Fig51
[ARMEMENT] OERLIKON 20mm : Documentation Fig075
Projets en cours:
SS Delphine 3D
Projets en cours:
SS Delphine 3D
https://youtu.be/W7qExnBNWJk
Projets en cours:
SS Delphine 3D
Je suis en train de modéliser les éléments de pont de l'escorteur d'escadre Surcouf à partir de plan de chez new maquettes.
Ca donne une vague idée de ce à quoi ça doit ressembler !
C'est un bateau donné et en cours de restauration, il n'a que la coque !
Une fois fini il sera donné au musée de la marine à Toulon à priori Wink
Par contre il faut que je modélise un canon de 20mm et vos documents sont non accessibles.
Pourriez vous m'en transmettre une copie, ainsi que tout ce que vous pourriez avoir sur le Surcouf ?
Merci d'avance.
Alain
Le monde est peuplé d'imbéciles qui se battent contre des demeurés pour sauver une société absurde. (J.Yanne)
Effectivement le lien est mort, je vais t'envoyer un message privé.
Projets en cours:
SS Delphine 3D
Merci  Respect
